Q-75 or 3W 75?
Old 08-17-2003 | 01:13 AM
Steve's Avatar
My Feedback: (54)
Default Q-75 or 3W 75?
Anyone know how the Quadra 75 compares to the 3W 75 as far as power, prop, and rpms?
Steve
Old 08-17-2003 | 01:33 AM
My tach says the ZDZ-80 is significantly stronger than the 3W-75, at least 500 rpm more on a Menz-S 26x10. The 3W is a little less money ($50 cheaper), but weighs about 1 pound more.
Old 08-17-2003 | 02:11 AM
we just tached our 3W-75 today with a menz "S" 26-10 and got 6100.
Old 08-17-2003 | 12:37 PM
Steve's Avatar
My Feedback: (54)
I will be needing more pull out of a hover and less forward speed. So I will probably stay in the 6 to 8 pitch on the prop. I have a BME 102 motor for my 31% CA 300L but it doesn't fit in the cowl. They recomend a 3W 75 and I have a Quadra 75. I just don't know how much power I will loose if I use the Quadra. Weight is about the same on both motors if I use the Quadra B model and I need about a 5 pound engine for balance. Thanks.
Steve
Old 08-17-2003 | 12:47 PM
Either motor will be plenty for the 31% CA. It will probably come out around 23 lbs.
