RCU Forums - View Single Post - GP Extra 300S 60 Build
Old 07-14-2011 | 11:42 AM
  #372
EscapeFlyer's Avatar
EscapeFlyer
Default RE: GP Extra 300S 60 Build
Andrew
The belly tuck could simply be a balance issue. I'm sure it flies great as is, but an adjustment may fix a lot of the tuck issue.
There is probably a little pressure on the rudder too, so it most likely won't all go away.
Now that I know it will KE, I think I'll pull the trigger. I was getting told from everyone I knew that the airplane wouldn't do this.
Brian
