RCU Forums - View Single Post - Cub
Thread: Cub
Old 07-15-2011 | 11:15 AM
Free Bird
Default RE: Cub
quote:
ORIGINAL: Ken Kehlet
Two Cents from an old Builder/RC Flyer, Bend the Landing gear to have abour 2 degrees ''TOE-IN'', you know, point the wheels towards the NOSE slightly. This ''TOE-IN'' will help in ground handling and take-offs.
Than start you Take-Off from the grass.
If you want to make better landings, Line the model up on your shoulder, make your normal approach, as the model gets down to about two (2) feet from the ground, FOCUS your eyes to the MAIN WHEELS, Watch the Main Wheels and feed in elevator for a perfect Landing. Same is true on Tri-Gear, Focus on the Main Wheels. If you just watch the whole airplane, you will hit on the NOSE Gear almost every time.
Happy Take-offs, and Landings.
Ken AMA 1528[/size].
All good stuff Ken and I couldn't agree more. Thank you!
I was going to suggest the same thing, wheel alignment is very important (more so) on a taildragger. I had the same type of issues once on a taildragger and adjusted the wheels so they had a little "toe-in" and the plane was a different animal after that. Good Luck and let know how you make out!
FB
