ORIGINAL: Link119
Why is one picture upside down[&:]
The tires make it look like a 4x4
Cause he's obviously defying gravity! LOL
Those tires do make for a very beefy looking car. What size battery are you running? Have you thought about getting an alumium gear box to help combat the high motor temps? If your on the upper end of temps, 180ish, you should see about a 30° drop in temps just by switching the gear box. It acts as a giant heat sink for your motor so you should even be able to run the same gearing maybe a little higher. The integy one is the cheapest I've seen but also seems to be the one that has had the most defects but still a small amount of them. Golden Horizon makes one for about 10 bucks more and comes with a lifetime warranty.
