RCU Forums - View Single Post - lightning bug almost there
Old 07-17-2011 | 06:18 PM
AMB
Default RE: lightning bug almost there
Hi with engine running only the metered amount will be allowed by needle setting,if you let it sit fueled you might get a syphon effect, close the needle none should run into the engine, and I do not let them sit around fueled , its fill start and go martin
Forgot my Nouvo 1300 electric to diesel conversion TT10GP Davis head set up to the same height and this runs muff pressure runs fine no issues
well progress wiring complete went larger wheels 2 1/2 inch for grass field and wngine area painted
ID:	1636696   Click image for larger version
