RCU Forums - View Single Post - JetCat P-60 Problem
Old 07-18-2011 | 10:46 AM
Thud_Driver's Avatar
Thud_Driver
Default RE: JetCat P-60 Problem
Regardless of the light sequences, did you hold the the Select menu button down on power up long enough to see if it would cycle past Learn RC to Calibrate Temp???
If you can't get this to work you should probably send it in to JetCat.
