RCU Forums - View Single Post - evojet 160 calibration
Old 07-18-2011 | 11:47 PM
bandit_av
Default evojet 160 calibration
Hi
We have the evojet booster 160 (not the vx) which was bought in 2009 and never run since then,
and we have a little problem in the ECU adjustment.
we are trying to adjust the max. rpm from 120000 (factory setting) to 116000 so after doing it the ECU shows the
max. rpm 116000, BUT after switch off the ECU and turning on again for a regular use
the ECU shows that the max. rpm is adjusting to 120000!
so, how do I teach the ECU to stay in the rpm which I want it to be, and not the factory adjustment
to the max. rpm.
Thank you in advance
Avi
