RCU Forums - View Single Post - dual rates and expon extra 300 e
Old 07-19-2011 | 01:31 AM
radius1x1's Avatar
radius1x1
Default RE: dual rates and expon extra 300 e
Just a note on expo; be carefull after 50%. Yes it is true the sticks will be more forgiving around center, but then the curve goes straight up at full through and becomes very twitchy. Expo does'nt change the total deflection of the control surfaces. It just delays full through to extremes of the stick movement. To add expo on a Spectrum use +; on Futaba radios you use - to add expo.
