RE: FEJ L39 1/7TH
Sorry this is slow going but ran into a few snags.I decided to go with the electric modification from "Down and Lock"I will be sending the gear out today after not being able to get someone on the phone for a week.Spoke with Ron,real nice guy and said I have the gear back in three weeks.The gear will be electric and the doors will be air.The other snag is the flap sevo tray.The tray must be sandwich between the skins.On the lower skin this is done by fitting tabs between the tray and skin at each corner of the box.I cannot install the tabs in the flap opening due to the aft side the tabs are in conflict with the flap hinge support blocks.So I have come with three options to work around this.If anyone here has run into this problem let me know.I'm thinking since the hinge spar is so close to the servo tray box just to fill the gap with a solid 3/4 balsa block and have a solid connection to the tray.Also was missing one of the two push rods for the elevator,. called James and he has the replacment on the way.Thanks james.Sorry no pics but really not much to see yet.
