RCU Forums - View Single Post - High thrust 70mm EDF HELP !
Old 07-28-2011 | 12:01 AM
Extreme_RC's Avatar
Extreme_RC
Default RE: High thrust 70mm EDF HELP !
Yes true, I seem to recallthe guys who have posted up test results over on rcgroups at altitude usually show a drop in amps and thrust, you can go hotter with your setup without getting into too much trouble, just remember your watt meter is your friend, test everything on the bench first to make sure of your baseline.
