ORIGINAL: marc s
Whats the tank with the red label on it.??? Different from the others..
Appreciate the comments Jeremy, the red label version is specifically for the P20/Kolibri and nano turbines, the barb fittings are for 4mm OD feed and supply, with a 3mm OD fill. As its the same size as the small CAT it was to distinguish it at a glance from the other.
marcs
Marc, thanks for reply, great to see your tank in the flesh, as big plums said, swish, or the dogs bollox come to mind...:-)
Craig has his in the MIG already, and is test running it over the weekend, hope it solves his past problems with air... let you know,
Jeremy.
