RCU Forums - View Single Post - Nitroplanes.com Absolute worst C/S
Old 07-29-2011 | 08:05 AM
  #55
walkermsg
Default RE: Nitroplanes.com Absolute worst C/S
I just received my Nitroplanes AIrfield whatever, the box had two holes in it, before I could check for damage the UPS guy was out a there in a flash. Only damage the tip of the tail was broken, some glue and splints held with rubberbands fixed that easily. The plane is a real beauty. I flew it this AM 4 times. It has 3 set screws in the front wheel and 2 worked lose after the 3rd flight. That's pretty much normal on any plane. I tightened them and continued to fly. This plane is well built cowling and door under fuse held with strong magnets. My only issue with the company or plane is getting spare parts like a couple 3 blade props 11*9*3 . Can't seem to locate any. That has me worried a little, Nitroplanes seems to be out of almost everything. I'm not sure what this means. Going belly up ? Not enough stock on hand? So far I am very satisfied with Nitroplanes and the plane.
Lee
