RCU Forums - View Single Post - Choking before using the spring starter ?
Old 07-30-2011 | 05:13 PM
w8ye's Avatar
w8ye
My Feedback: (16)
Default RE: Choking before using the spring starter ?
Rocking the prop just runs the fuel pump
To get fuel up into the combustion chamber, you need some full revolutions
This is described by Karolh
Engine created vacuum can suck fuel past the pump and metering valve and into the engine if the carb inlet is completely closed off while the engine is being turned over. (Not recommended)
