Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 Choking before using the spring starter ? >
Old 07-30-2011 | 08:42 AM
Ed
Default Choking before using the spring starter ?
I've seen people choke the Carb, and rock the prop back and forth on compression a few inches, and then again, I've seen people make several full 360* revolutions of the prop while choking. Which do you think is more effective ? Wouldn't a full revolution draw fuel further into the cylinder ?
Thanks .
ed
Old 07-30-2011 | 12:16 PM
My Feedback: (9)
Default RE: Choking before using the spring starter ?
I have a spring start on a G62. I choke it and use the spring start until it fires, then no choke and it starts right up.
Sam
Old 07-30-2011 | 01:35 PM
ORIGINAL: Ed
Thanks .
ed
I use the choke on prop rocking motion to get fuel into the carb, and then do a couple full prop flicks to prime the cylinder. Can't say for sure which one is more effective by itself as both methods work. One thing for sure is that the prop rock method can get an engine flooded in a hurry if one is not careful.
Karol
Old 07-30-2011 | 02:37 PM
nonstoprc's Avatar
My Feedback: (90)
Prop rocking is easier than the full flips. It is quite effective to draw the fuel to the carb.
Make sure you count the # of rocking motions such that the fuel is at the carb. Then a couple of flips to pop the engine. Next time, it will be a habit.
Old 07-30-2011 | 05:13 PM
w8ye's Avatar
My Feedback: (16)
Rocking the prop just runs the fuel pump
To get fuel up into the combustion chamber, you need some full revolutions
This is described by Karolh
Engine created vacuum can suck fuel past the pump and metering valve and into the engine if the carb inlet is completely closed off while the engine is being turned over. (Not recommended)
Old 07-30-2011 | 06:15 PM
ORIGINAL: DaddySam
Sam
Good call.
Old 07-30-2011 | 07:07 PM
Ed
" Rocking the prop just runs the fuel pump
To get fuel up into the combustion chamber, you need some full revolutions " - W8YE
This is exactly the reason that I asked the question. Thank you for verifying.
Ed
