RE: turbine electric generator
redesign the bearing tunnel behind the front bearing to hold a brushless motor magnet on the shaft and enlarge the bearing tunnel to hold the windings.. presto... all the power you want, may be even too much, then use that as the starter also, but that takes a fair bit of electronic expertise.
