RE: DLE 30 Idle question...
The Dle 30cc engines need breaking in before you will get real nice steady running at various RPM levels. The fastest way to break them in is called heat cycles. Run it up to temp.using various seed/loads and shut it off. Let it cool and repeat sereral times. You can do this while working on other items around your house/yard/nest ! Capt,n
