RCU Forums - View Single Post - problems again...
Old 08-05-2011 | 09:35 AM
icedude1989
Default RE: problems again...
check if the pinch bolt on the pinion is loose or if the spur gear is n contact with the pinion. if the pinion is loose, u should see the motor shaft spinning but the pinion remaining stopped. tighten the pinch bolt (small allen key in the side of the pinion)
