ORIGINAL: zx32tt I have a A9 that I'm trying to program w/ a 7ch Optima. The TX seems to lose the link. I went thru the bind routine and everything seemed to be working properly. I switch everything off, come back a few minutes later, and I've got zip. The LED's on the rx are both on, but they are blinking on the TX. I have one other model stored on the TX, and it works fine. I have done none of the updates. Battery voltage is good on both TX and RX. What am I doing wrong? zx32tt
Scan mode can be linked to only one Transceiver at a time -must be re-set each time you change.
Suggest" Normal" mode be used as is used even in the big events.
Understanding Difference and when to use AFHSSNormal and Scan Mode
LED Status Card -
What the colours/combinations are indicating.
. Digital .pdf copy which can be printed and inserted as a page in manual or extra cards made.
AFHSS - ID_Setup (also known as Binding or Linking) & Range Test Procedure Aurora 9, Spectra 2.4Ghz Module <> Optima Receiver.
ex Hitec USA Support Forum Sticky:
Aurora 9, Spectra Modules & Optima Transceivers
- FAQ & Undocumented Features
- Mixes, Setups,Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
