RE: 2s on Micros?
Would be the same setup for brush type ESC. Cut the +,red wire on the ESC that goes to the batt. and install the Diode with the white ring on one end, towards the ESC. You can get the diodes from Radio Shack. The package I have says EPOXY RECTIFIER 3AMP/400 TIC. The power to the motor jumps from 3.7 to 7.4 volts. You will likely need a different motor that will hande the higher voltage. Hope this helps.
