RE: Delrin for carb adapter??
When CH did the Poulan 46 we used a Delrin intake. It would distort under high heat. We ended up with a 2 piece intake. An aluminum part that attached to the spigot and then a Delein donut as a heat dam. The Delrin spacer was under compression loads and worked fine
