Delrin for carb adapter??
Old 08-08-2011 | 09:00 AM
av8tor1977's Avatar
Default Delrin for carb adapter??
I have some partially converted Stihl engines I want to finish up. They have the "spigot" style carb intakes on the cylinder like the Poulan 46cc. I have some Delrin I could use to make up carb adapter manifolds. Does anyone have actual experience doing this? Will the Delrin hold up, or will it melt?
AV8TOR
Old 08-08-2011 | 09:34 AM
Default RE: Delrin for carb adapter??
At one time I made a delrin reed valve rear housing for my Ryobi test project. It worked just fine.
Old 08-08-2011 | 01:06 PM
tkg
When CH did the Poulan 46 we used a Delrin intake. It would distort under high heat. We ended up with a 2 piece intake. An aluminum part that attached to the spigot and then a Delein donut as a heat dam. The Delrin spacer was under compression loads and worked fine
Old 08-08-2011 | 04:05 PM
av8tor1977's Avatar
Hmmm, that's what I was worried about with the Delrin. You wouldn't happen to have any pics would you Terry?
AV8TOR
Old 08-09-2011 | 07:53 PM
KenLambert's Avatar
My Feedback: (107)
I use aluminum and a plastic or delrin heat sheild . They are Cnc machiNed .
Old 08-12-2011 | 07:22 PM
The nice thing about Delrin is the fact it loses it about the time your engine is getting into trouble.
If the temps are high enough to cause problems with the manifold you have other issues to concern yourself about.
