RCU Forums - View Single Post - Engine help please
Old 08-08-2011 | 02:42 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Engine help please
Sounds like you have some junk in your carb. Disconnect the fuel line going in to you carb. Connect the fill line from your fuel pump the the carb. Remove the needle valve from the carb. Complete close the throttle. Now pump a little bit of fuel into the carb to flush out any debris. Put it all back together and see if that helps<div>
</div><div>Ken</div>
