RE: Ignition and Choke Switch on TX
Yes, I am anal as well, I like to have all my switches set up the same on all my planes, and if they don't have flaps or gear I don't use those switches, keep it all the same, no variation; I like your suggestion using the Trainer Spring Loaded switch for the Ignition Kill and since I will have a manual switch to disconnect the battery and the LED is easily seen would not be a problem.
