RE: Engine help please
also check for a possible leak in the pickup line inside the tank. if the fuel level is higher then the pin ***** in an inside fuel line then fuel flows easily to engine but if the hole is exposed to air in the tank then the engine will run lean or stall. you then fill the tank level higher then the pinhole leak and the engine works great again
