RE: Elevators will not sync W/11X
All contributors to my post<
I have removed the servos from plane, made a mount w/center hole for output shaft and housing w/180 degree compass and measured degrees of travel on each servo. Of course, they measured identical degrees of travel.
You did ask me to view the monitor which I did and you said elev and aux 3 should move opposite by default. They both move the same but in the same direction which I assumed is because I reversed ch.or aux3 so it would move in unison with elev ch.
Back on the mechanical end, I again measured the push rods and control horns and they are same height and both on hinge centerline.
Well, for the umteenth time I am going to get your notes and Barracudahockeys notes and go through the radio again. Has to be an OVER SIGHT or probably something STUPID ON MY PART!!
Been a long HOT day. Screens are starting to look the same. Early morning catching up
Thank you every one!!!
