RCU Forums - View Single Post - using a lipo in the DX7
Old 08-13-2011 | 04:21 PM
opjose's Avatar
opjose
Default RE: using a lipo in the DX7
I charge my LiPo's outside the TX.
Gorish
I'm still confused as to what you are looking for?
I've used these on my JR/Spektrum TX's.
[link=http://www.hobbyking.com/hobbyking/store/__7346__Rhino_2620mAh_3S_11_1v_Low_Discharge_Trans mitter_Lipoly_Pack.html]Click me![/link]
As you can see in the picture it comes with a standard white balance port, and a standard RX/servo type connector.
I made the RX/Servo connector into the plug needed for my JR/Spektrums using the plug from an old battery.
As I mentioned in the prior post, about being better off with LiFe batteries... LiFe batteries can be had with the correct JR/Spektrum connectors already installed...
See: [link=http://www.hobbyking.com/hobbyking/store/__14076__ZIPPY_Flightmax_1800mAh_9_9V_5C_LiFePo4_T X_Pack.html]This link...[/link]
In both cases the white balance connector is used to charge the pack.
If your charger does not have a balance connector you can use one of these with any charger...
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXMGS7&P=ML]Equinox[/link]
Which come with a set of these as part of the package :
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNGC4&P=7]Connectors[/link]
Am I missing something?
