RE: Engine help please
When pinched at idle she will run about 2 seconds then fall off and stall. It does the same thing when I lift the nose up at idle. Also will run at medium rpm for a minute or so, then just die. Doesn't lean out or sputter, just dies.
I appreciate all the links and advice. I'm going to try a new carb. The are $20 and still available at Tower. I'm going to chock it up to voodoo and move on. If the carb doesn't work I'll get a new engine.
Thanks again guys!
