RE: Haunted RX stops receiving signal after sitting on haunted table untouched for 4 hours
Check the "Y" between the ECS's and make sure it is pluged into the throttle channel. You might test the "Y" by eliminating it - plug the ECS's into the Throttle channel one at a time and see if each is working. If so, the "Y" may be at fault.
