ORIGINAL: goirish
Seems like it is running OK-starts easy, idles good. Doesn't seem to be much difference between 1/2 and full throttle. Would that be normal? In fact it runs better at 1/2 throttle. Again thanks for all you did.
Yup, normal, and all the gassers I've run do the same thing. The first 1/4 or so of a gassers throttle arm travel have the most effect. We just got into this again over in the DLE 20 thread. There's a drawing in post# 4272 that shows how to handle this using your throttle and servo arm geometry. Several relevant comments follow. This link will get you to the right page:
http://www.rcuniverse.com/forum/m_98...71/key_/tm.htm
