RE: Type of material for scratch building
Hi Mad Modder,
Thanks for the Fast reply. I forgot to mention that I am scratch building a 1/16 Tank. I have the lower hull from a donated Tank with it`s running gear as well. So I need to construct the Upper Half etc. It must be able to hold up to I.R R.C. battles outdoors and in the heat.
So I need a recommendation for plastic sheet thickness. Also where can I get plastic sheet with diamond pattern on its surface for open floor use in the tank?
Thanks Again for Any help.
George
