RE: Haunted RX stops receiving signal after sitting on haunted table untouched for 4 hours
if your servos work when you power the system on ,then you know that those channels are fine.take a servo that you know works and plug it into the throttle channel to see if it works there.to power the receiver plug your speed controller to an open channel with
the motors disconnected so they will not throttle up.plug your battery to the speed controller.if the servo works you know
that the problem is either the speed controller or motors.if the speed controller is programmable,double check that.
if the servo on the throttle channel does not work then you have a receiver or radio problem.
hope this helps
