RE: Bee II ks questions
Hello Glen:
Thanks for your question. As for the fuel filter, we suggest installing it in line with the 4mm tubing going from the Y or T fitting to the turbine. The trick for installation is a good pair of needle nose pliers. Push the 4mm line over the end of the pliers as far as possible then pull the handles apart, hold, then twist 90degrees, pull and hold again. Then quickly remove and push on the filter nipple. The tubing will return to its natural shape. NEVER use heat. . .heat will ruin the tubing
As for the flame at switchover, we need to adjust the fuel pump start point. Please give me a call with your serial number and as well, be at your jet. We can do this in about 5 minutes or less.
Best regards,
Eric
