RE: New Sebart Wind 50E
Hi,
I use DesirePower V8 6 Cell (6S) 5200 mAh 35C in my Wind S50E. One such Lipo including the cables and connector (EC5) weight 760-770 gram (26.8 - 27.16 oz). Since I use the Hacker A50-16S V2 that is lighter (345 gram)then the original A50-16S V1 (395 gram) the LiPobattery should be a little more towards the nose with lighter A50-16S V2. On the other hand You can also balance withrudder servo in the tail or inside fuselage in the center spart. I fly usually 8 minutes but 9 minutes shouldbe no problem with this motor and LiPo combination and still have about 1000 mAh capacity left (about 20%). I use Castle Creations Phoenix ICE 100 ESC and use the built in BEC.
/Bo
