RCU Forums - View Single Post - KV-1 with DBU
Old 08-17-2011 | 06:01 PM
thecommander
Default RE: KV-1 with DBU
ORIGINAL: Airbrushler
ORIGINAL: Fireman Tim
Greg,
punch out the LED for the airsoft gun and put the IR led in there. Mount it in a tube with the tip of the IR emitter recessed 9mm from the end of the tube.
You can also mount your receiver in a hatch. Paint it if you wish, just don't block the window to the receivers.
Thanks Guys
i might leave it like it is for now you know me i might change it 50 times later on...lol
i had no room to put it in the hatch the airsoft gun and motor are right there i kind of went with what i seen on what Thecommanders had on his only thing is i made mine look like another gun
You saved me the trouble of posting the pic of my HL DBU KV1...thanks. This was the first DBU tank at the Danville battlefield and it scored several kills that weekend along with Steve's (AKA Shenlonco) DBU Walker, which is also brought with me. Steve has not made it there yet. But I'm still trying to get him down there. As you found out the "Apple" can't be put at the hatch and the remember also, the HL KV has NO depression. You will notice my emitter points downward to impart some depression which is a must for my battle style. ALL Danville tank emitters MUST have a emmiter shroud (internal or external) to constrict the IR beam. If not friendly fire issues from the shotgun effect will be an problem. I have been mounting the IR emmiters in the LED & HL IR emitters for 2 years now. Be forewarned the stock HL KV with DBU has very little power or turning ablility when burdened with 7 or 8 hits.
