RE: Engine help please
sounds like your main needle is slightly too lean, when you start the engine with a full tank it is perfect, then after 3-4 min its just a tiny bit harder to draw fuel so it leans out and dies. this should also help solve your leaning out problem on the low end as well. i would back it off about 5 clicks and try again.
