FG-14b for SPA???
I just came out of a hole in the ground and started flying my Kaos again, preparing to make a showing at the next two contest here in Fort Worth. Although the plane flies good, after each flight I can't help but to start thinking that the Compensator short kit I have in the attic would be awesome! Yesterday, while searching for engine options for another project I stumbled upon the Saito FG-14b, and started wondering... The weight seems like it isn't bad, and if the thing truly sips fuel as they say, a smaller tank should offset the ignition module's added weight. I have used the hitec 5245 servo on a .60 sized pattern plane in the past, and was thinking with those servos, a light 2s lipo, and a diligent approach to controlling the airframe's weight, it could be about 6.5 pounds. Any of you guys seen this engine in action, or have any thoughts on this combo?
Blake
