RE: Noobie needs help w/control problem
Hey, Aframomum! Thanks for the shout back. I'm starting to discover how much fun CP is, I'm just having some teething problems.
Transmitter is a WK-2402. Part of the problem is that I can't really get my head around the instructions - yes, I can understand the programming instructions, reversing servos, etc, but I don't know how to achieve what I'm looking for. I know squat about swashplate type, rudder mixing, pitch adjustment, etc. Right now, with the throttle all the way down, I have a fair amount of servo travel. But the second I spool up, the servo travel drops drastically, almost zero in fact.
Expo is off, even though I had turned it on and saved the setting. Seems to turn itself off when the transmitter powers down. I had it on to try to set a normal throttle and pitch curve, but I can't see that I've accomplished anything.
What I need is CP Heli Setup for Dummies or the equivalent. If you have a recommendation, I'll certainly check it out!
Thanks!
