RCU Forums - View Single Post - SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION
Old 08-25-2011 | 12:27 PM
  #629
optech
My Feedback: (9)
Default RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION
ORIGINAL: Pull Up Now!
Adrian, does that C1QP8 carb have the 4-stroke pump helper spring(for negative-only pulse), and is there an accelerator pump like the WT456-1 has?
Like Adrian said, the rep was quoted as saying they use a plastic that has enough "spring back" when the pressure is gone to provide the pumping action. He also said that they have springs available should the plastic return not be enough for your application.
Later,
Mike
