RCU Forums - View Single Post - Smallest CM-6 spark plug boot
Old 08-27-2011 | 02:24 AM
ticketec
Default RE: Smallest CM-6 spark plug boot
ORIGINAL: w8ye
The CH ignition systems that used a rubber boot that had the wire braid from the spark plug wire gathered up and gounded at the plug base used a resistor type spark plug
Yes, but what is the difference from an RFI perspective? A resistor type spark plug requires a resistor inline with the high tension lead before the plug, the other type does not. but does this have any effect on the interference that may be emitted?
If it does, can you cover the rubber boot with a wire braid to have the same shielding effect?
dave
