NOT YET BUT HOPE TO
Hello JP-14
Im just putting the finishing touches on my Seagull Edge 540, I did reinforce the Horz. stab with wire struts and a few other modification to the wing & fuse to straighten the wing. I did reduce the high rate & low rate throws 1/8 that is recomended in the manual.
I hope to have in in the air when the heat and humidity goes down alittle.
You might want to check out some of the threats already started here in RCU. Just type in Seagull Edge 540 . Some of the guys have posted there flight reports there.
It is very well put together ARF
NEDYOB
