RE: Smallest CM-6 spark plug boot
NOT A REPLY...A IDEA
I wonder id a person took a standard Rcexl ignition and used s resister wire for the hi tension lead and a rubber cap, would this work? I know you would need a seperate ground wire (real short) to the aluminum case on ignition box. Seems like a fun experiment!!! Range test....then maybe test fly on a junker! Capt,n P.S. I bet Bill Carpenter would know!
