RE: chit chat thread
ok so i have stepped down to his level. Ive reported about 4 or 5 of his personal message. He should be getting the ban hammer anytime soon now.
I took my extra 260 and parkjet down for a fly this morning.
The parkjet is very easy to hand launch now. Once you know the right method then its easy. I found i have plenty of ailerons but not much elevator. I was able to roll it with easy but pulling back on the stick is a task. I put two lipos through it. I still think its not fast enough on the 2s setup but i think ill leave it like this as i need to use up the 2s lipos i have. I know for sure if i put it on a 3s setup i will crash it for sure. Its a pretty boring little wing but it gives me something else to fly.
I had a couple of flights with my extra 260 as well. It has a 35-30 1700kv motor and an apc 8x4 prop. I have come to the conclusion that this motor is way to fast for this plane. In the near future im going to take the 35-30 1100kv motor thats on the hyperion snyper and put it back into the extra 260. I think ill then order a 35-36 900kv motor for the hyp snyp and put a 12x6 prop on it.
The extra as is, is a blast to fly but its only good for fast passes. I will be able to do this with the rare bear soon. Although the extra does not have much of a rudder i might mod it so its a little bigger soon and try some 3d with it.
Anyways i want to get my hyperion snyper flying really good. Theres so much this plane can do if set up right. Hopefully a new motor and prop will help it alot.
I put a few packs through my little mcpx as well but the wind came.
They literally turned the sprinklers on me at the park i was at. So i packed up and came home.
Had a good day of flying. Now to jump on the sims and do some crazy flying.
