RCU Forums - View Single Post - boats
Thread: boats
Old 08-21-2003 | 07:46 PM
Jeff Wohlt
Default boats
There is a cat out by MHZ that comes with 2 motors and drive tubes and the cat is glass and nice but they are going for around $190...then you need the hardware...strut, etc. The hull alone is around $120. Or oyu can go with a ABS Scat cat which my son has and is very fun with 8 cells and a 600 motor. Good run time...won't roll over at full speed and does great jumps and run time is very good.
I could build it with hardware (custom) but you will still need an ESC, radio and packs.
They are hot little boats. You can save yourself some trouble by going with one motor and standard drive...unless you are dead set on dual drives...they look cool but are a bit hard to tune...each motor runs a bit different.
I am finishing a Force 22" v-hull that will have a 600 motor in it and would be perfect and fast for 8 cells. My 8 cell packs are 2x4 which works best in Cats and small v-hulls.
It can be built to run flex shaft, wire drive or straight hardshaft.
I build the struts, brackets and all else. Never a failure on any of it.
All you would need is ESC, radio and cells to get it going. You can paint it yourself or have me paint it to your specs.
