RCU Forums - View Single Post - Futaba 4PL receivers
Old 08-30-2011 | 06:09 PM
Post-Amerika
Default Futaba 4PL receivers
Hello!
I am the proud new owner of a Futaba 4PL and I am wondering how the receivers are bound with the system.
I follow the instructions and all works fine, but I am more concerned with how the system recognizes each receiver.
I understand the model memory, and I know that you are able to switch between them, butare there a certain number of receivers that you can bind with the radio?
For example, if you bind one receiver to the radio and set the receiver settings (trim, EPA, dual-rate, etc.) you will have that model good to go. If you bind a second receiver to the radio, it will just bind it to the system, and you will have to switch to a different model to get it set up for that specific car. I think I am correct in assuming this. I just wanted to be sure!
Thank you for your help!</p>
