Futaba 4PL receivers
AP
Hello!
I am the proud new owner of a Futaba 4PL and I am wondering how the receivers are bound with the system.
I follow the instructions and all works fine, but I am more concerned with how the system recognizes each receiver.
I understand the model memory, and I know that you are able to switch between them, butare there a certain number of receivers that you can bind with the radio?
For example, if you bind one receiver to the radio and set the receiver settings (trim, EPA, dual-rate, etc.) you will have that model good to go. If you bind a second receiver to the radio, it will just bind it to the system, and you will have to switch to a different model to get it set up for that specific car. I think I am correct in assuming this. I just wanted to be sure!
Thank you for your help!</p>
i have onethat controlsmy baja and my cr-01. 1 4pl transmitter and 2 recivers. one for each model.
just change to what model you are gonna run on the reciver then turn on the rc car and wait a sec for it to sync up and your good to go.
AP
Perfect! I thought that it was how the transmitters/receivers worked, but I wanted to make sure.
It's my first time owning a radio of this caliber so I wanted to make sure I'm doing everything right.
Thank you all for your clarification!
