ORIGINAL: flyierjon
Hi all, its been awhile for me, just getting back into the swing of things and last I was flying was regular 72 and am in the process of switching to 2.4 will I be able to run my 6 volt batteries 2300mah on the spectrum receivers??? or will this cause overloading? what is the best way to go using this battery?
Jon
The receivers have no problem with 6v. Some servos are not compatible with 6v. Check the box the servos came in or call the manufacturer
