RE: Low end tuning
Set idle to about 1800, lean the low..RPM will increase..Reset speed to 1800, repeat until this procedure no longer results in rpm increase..At this point try transition, it will probably die..open low until it doesn't die on transition...fine tune from there...Re check high, a rich low will give a false reading on high....
