My way just assures that a low needle only needs to be turned one way after hitting the peak. It WILL have to be richened for good transition. The nice part about my way is you only set the throttle stick once and then are assured you have to richen up. Either way you'll end up cycling the throttle stick from low to high after the initial peaking to obtain the best transition.
Jody doesn't know what he's doing either but if you prefer that method don't be scared
Listen to what a1pcfixer said. It matters,
a lot.
