RCU Forums - View Single Post - Low end tuning
Old 08-31-2011 | 06:42 PM
Tired Old Man
Default RE: Low end tuning
ORIGINAL: CustomPC
Hi Titan's
What is your opinion on this method that i have seen posted around on a few places
Set the lowend & highend needles to about 1 3/4 to 2 turns each. Choke the carb or prime it, until the carb is wet. Fire up the engine and let it warm up. Let's set the topend first since it's the easier of the two. Go to full throttle. Adjust the topend needle for peak RPM. Leave it wide open for about a minute to see if it changes any. Should the engine go lean, open the lowend needle slightly, if this dosen't work... you will have to adjust the needle valve inside the carb.( I will explain this later) If the topend runs OK, then slowly pull the throttle down until the engine begins to ''four cycle'' hold the throttle there. Adjust the lowend needle until the ''four cycling'' barely stops. Now lower the throttle more until it ''four cycles'' again, and adjust the lowend again. Keep doing this until you reach full idle. Now, from full idle begin to throttle up until the engine starts to bog or hesitate. Open up the lowend needle just enough to eliminate the bog or hesitation.
When this is done right, you will be able to set the throttle in any position and it won't four cycle, plus you will be able to transition from idle to full power without any hesitation at all. Now, for easy starting it's best to have the lowend a little rich and it will four-stroke a little.
Toss it for numerou reasons, starting with the initial needle positions. What does "carb is wet" maen? Did someone pour gas or water on it? How wet is "wet"? Adjusting the level presumes you know what the level should be and how to make changes correctly. You and most others don't, and won't. Also makes the assumption that all engines will react the same to the same inputs. They won't, and don't. Too many definitions of "four cycle" so the term will confuse half the people using the method. Just what does "barely stops" mean? Some engines will never be rid of a "four cycle" in certain RPM areas. The cheaper they get the more often that happens. Some expensive ones can go the same way.
