ORIGINAL: VIRGINIA MODEL BUILDERS
<div style=''text-align: center; margin: 0in 0in 10pt'' align=''center''><span style=''line-height: 115%; font-size: 16pt''>DLA ENGINE CONSTRUCTION</span></div><div style=''margin: 0in 0in 10pt''><span style=''line-height: 115%; font-size: 10pt''>Here are some answers I have gleaned that may help.</span></div><div style=''margin: 0in 0in 10pt''><span style=''line-height: 115%; font-size: 10pt''>
</span><span style=''line-height: 115%; font-size: 10pt''>The billets are forged.
The crankshaft is Steel alloy grade 8620 (also called nickel-chromium-molybdenum steel)
The hardening and finishing techniques used on the bearing cavities areas are
Hardening: Induction hardening, Finishing: Hard turning, Dynamic balancing
Finishing (polishing and lapping) </span></div><div style=''margin: 0in 0in 10pt''><span style=''line-height: 115%; font-size: 10pt''>
The bearing fit used is called a tight fit (or shrink fit). It provides uniform load support over the entire ring circumference without any loss in load carrying capacity.
The cylinders are Honed
As for the major components (Cranks, Pistons, Rods, Cylinders) being any different than those readily available from the two major component suppliers in or near Zhejiang. ihave know idea</span></div>
well there you have it,what say all of you now.
